Repair and support for Slinky Toys. A coiled spring made of metal and/or plastic.
2 Questions View all
How to untangle a slinky as fast as it got tangled
I know you can work the tangle to the end (normally). Mine is welded closed at the end, so that’s just moving the problem to a new part of the slinky… But also, it made me ask the question I’ve always wondered: What is the trick to UNDO the original tangle. After all, if it’s that quick to tangle, it must be undo-able in 1 slick little move…
Any ideas
Score 2
Add a comment
Most Helpful Answer
I've not met a person so majestic to rapidly undo the knot of a slinky. But I can tell you that my method of undoing slinkys are relatively easier.
I would suggest stretching it out carefully to see where the knot is in the first place.
Then if you want, you can slide your thumb slowly through the coil, aligning everything in place slowly working your way down to the knot.
And then once you make it to the knot, flip it or untangle it slowly as you work your way down, carefully pulling the overlays apart.
Score 3
Add a comment
Mike De Butts depends on how it is tangled. Most common method is outlined on here
Score 1
Add a comment
i love your name but get it ok here its goes. use a ruler
Update (12/01/2020)
22222222222222222222
Score 1
Add a comment
So basically what I did is I Kept rotating the coil different ways and eventually it came undone…Took around 10 mins depending on how much it is tangled✨
Score 1
Add a comment
Add your answer
Mike De Butts will be eternally grateful.
Past 24 Hours: 7
Past 7 Days: 70
Past 30 Days: 261
All Time: 16,139
