2.5 GHz dual-core Intel Core i5 processor (Turbo Boost up to 3.1 GHz) with 3 MB shared L3 cache.
265 Questions View all
Charge port replacement question
Hi,
My computer has had trouble charging. I replaced the charger (onE of the pins was stuck) but the problem has persisted. I noticed some burn marks on my charge port and and looking to replace it. Which charge port is the correct one? and which repair guide?
my macbook is a A1278 model, serial number is: C1MMHY1KDTY3
Add a comment
Most Helpful Answer
@tootscoots according to your serial number your MBP is actually a MacBook Pro 13-Inch "Core i5" 2.5 Mid-2012
2.5 GHz Core i5 (I5-3210M)
Intro.June 11, 2012
Disc.October 27, 2016
OrderMD101LL/A*ModelA1278 (EMC 2554*)
FamilyMid-2012
13"IDMacBookPro9,2
info from here which would make it a unibody model. Heerr is the guide for that MacBook Pro 13" Unibody Mid 2012 MagSafe DC-In Board Replacement and the part is available right here MacBook Pro Unibody 13" and 15" MagSafe DC-In Board
MacBook Pro Unibody 13" and 15" MagSafe DC-In Board Image
Product
$9.99
Score 1
Add a comment
Charging ports are easy to damage. Constant connecting and removal of the connector cord can be hard on the port and move, bend, or damage internal components. Sometimes a dropped phone can also cause charging issues. If your phone or mobile device has stopped charging correctly krogerfeedback
Add a comment
Add your answer
foster anderson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 96
